| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#51
The fact that this is a logical Mosfet and I'm giving it power rather than a logical 1 or 0 has nothing to do with it? It's a IFRZ4NN. |
#52
This has nothing to do with IRFZ44N being a logical Mosfet or something?
#54
Quote:
This seems like the kind of problem I'm having?! Could it be that my Mosfet is not a logical one? How can I test that feature? thanks |
#55
What type mosfet are you using? In your schematic you state IRLZ44N, wich is a logic gate mosfet. Greetings, Bertus
__________________
You don't have to know everything, if you know where to find it. When you do ask questions, you may look stupid. When you do NOT ask questions, you will STAY stupid. It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.(User CP -> Edit Your Details) |
#56
Quote:
What I'm trying to find with the measurements on the MOSFET while it is supposed to be on and supposed to be off will answer quite a bit. While on, the voltage at the Drain should be very close to the voltage at the Source. If not, the gate voltage must be less than 5V. When the black lead of the multimeter is on the Arduino ground, what does the +5V of the Arduino show? Without moving the black lead/ground, what does the +24 volt supply read? Without meaningful voltage measurements, it is very difficult/impossible to troubleshoot. |
#57
Noooooooooooooooooooo, My Mosfet is IRFZ44N and NOT IRLZ44N!!!!
Is that why? No wonder they were cheap like $0.25 each! Please Confirm! |
#58
The IRFZ44 is a "standard" gate mosfet, and not a logic gate mosfet. I attached the datasheets for both types for comparisson. Greetings, Bertus
__________________
#59
I have adopted the circuit for IRFZ44. Greetings, Bertus
__________________
#60
Bertus,
Thank you so much for the advice. Please recommend a type of Zener Diode also let me know if a IN4007 would do or not? Also any good readz on what a Zenner Diod does? |
| Bookmarks |
| Tags |
| arduino, duemilanove, mosfet, question, transistor |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Which solution for Arduino data storage? | empewoow | The Projects Forum | 3 | 11-08-2009 09:41 PM |
| Project: Arduino line following robot | Aklem | Embedded Systems and Microcontrollers | 2 | 09-29-2009 12:28 PM |
| interfacing a resistor ladder to an arduino analog input | Steve C | The Projects Forum | 7 | 09-01-2009 02:38 AM |
| Arduino LCD Keypad Questions | Colossus | The Projects Forum | 8 | 08-14-2009 10:46 PM |
| why arduino over PIC? Why PIC over arduino? | Steve C | Embedded Systems and Microcontrollers | 11 | 06-06-2009 06:17 PM |
