All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 11-03-2009, 07:15 PM
walid el masry's Avatar
walid el masry walid el masry is offline
Member
Send a message via MSN to walid el masry Send a message via Skype™ to walid el masry
Default
if you want to build a pc you will not need to change any thing in it say for 10 or 5 years what do you think about the specification for Intel and AMD ?
  #12
Old 11-03-2009, 07:26 PM
BMorse's Avatar
BMorse BMorse is offline
Senior Member
Default
Quote:
I actually prefer Intel based PC's than AMD's, I had too many heating issues with AMD's, and Intel CPU's run a little cooler.... If a PC is built today and only used as a home computer, for standard "Home" computing it would be good for at least 5 years (by this time i would be considered a dinosaur!) , If you do a lot of gaming and are constantly keeping up with newer games, then I would say a new PC today will be good for 3 to 6 months, maybe a year, I say this because, it seems as everytime a new game comes out, you need a faster and better PC than what you already have, and most newer games are based on newer and better video cards.....
I had just built a PC about 1 year ago for a friend, (It had an AGP slot for video card....) and just recently I had to upgrade his Motherboard/CPU/RAM/and power supply to accomodate the newer PCI express video card he needed for a new game......
So basically a computer will be good until you need to upgrade something in it...... I have one PC I built in 1996 (WOW that was a long time ago) it still runs fine (win98), but all it is good for now is running my Homemade CNC PCB Mill/Drill....
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #13
Old 11-03-2009, 07:39 PM
Member
Default
yeah that's why i asked that question that you need to upgrade any thing by the time
i have
intel pentium d 3ghz 800mhz fsb 4mb cash
ecs 954 mother
1 gb ram x 2 800
hd 160 sata western
ati sappher 4670 1gb memory ddr3
power supply 450 w
samsung 17" screen
DVD RW samsung
CD WR samsung
  #14
Old 11-03-2009, 07:41 PM
Member
Default
when we talking about intel processor speciall about the cash what is the difference between saying L2 cash = 4 mb and L2 cash = 2 x 2 mb ?
  #15
Old 11-04-2009, 01:06 AM
Member
Default
until some body find a solution i have to use vmware with windows 2000
  #16
Old 11-04-2009, 01:20 AM
BMorse's Avatar
Senior Member
Default
Usually that would refer to Duo Core/Core 2 Duo (both are dual core no matter how any one says it...) CPU's (or Quad Cores) access to the cache, usually if it is a Duo core and says 4Mb L2 Cache it would be shared between cores, in the 2x2MB L2 Cache, each core would have access to each 2Mb bank of cache (in a quad core each duo core would share a bank of 2 mb each.....).....
__________________
  #17
Old 11-04-2009, 01:44 AM
Member
Default
mmmmmmmmmmmmmmmmmmm
  #18
Old 11-04-2009, 01:51 AM
BMorse's Avatar
Senior Member
Default
mmmmmmmmmmmmmmmmmmm
are you thinking about upgrading??
__________________
  #19
Old 11-04-2009, 02:03 AM
Member
Default
honestly yes i want to upgrade my intel Pentium D to higher one and the closest choose is the core 2 family but i want a processor with the same frequency (not less than 3GHZ) and also the cash may be higher (> 4mb) but the problem is that 1st we should check the compatibility of the mother to work with the processor cause the soket and the 65 and 45 nm tech and that's make me ask is it matter the tech of the processor if they have the smae soket size (LGA 775) ?
and if iam going to upgrade the mother 1st i want to get the
GA-EP41-UD3L
(rev. 1.0)
but it says about processor
"Supports 45nm Intel® Core™ 2 multi-core processors with FSB 1333 MHz"
"Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™ 2 Quad processor/Intel® Core™ 2 Duo processor/ Intel® Pentium® processor/Intel®®processor in the LGA775 package"
but no thing about intel pentium D processors then dose it not support them or just enough to say " Intel® Pentium® processor" ?
  #20
Old 11-04-2009, 02:06 AM
Member
Default
that's what iam using now
ECS 945GCT-M2/1333 (V1.0A)
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FET as a switch and FPGA ? sstbrg Homework Help 1 07-07-2009 02:26 AM
Complicated FPGA Problem moraali Embedded Systems and Microcontrollers 1 05-29-2009 10:00 PM
Is this logic feasible in FPGA? gotumal Embedded Systems and Microcontrollers 3 03-25-2009 06:38 PM
Programming onto FPGA secretstep Embedded Systems and Microcontrollers 1 08-11-2008 02:04 AM
FPGA or Microcontroller? Peter Pan Embedded Systems and Microcontrollers 3 01-08-2008 03:50 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
