| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
Hey, I decided to use a MOS FET to help control the voltage to a fan. And I am using a 7805(I Think) to keep the input voltage at a steady 5VDC to a POT. The Pot controls the voltage to the MOS FET, which in turn variably controls the fan. The 7805 gets very hot when I pass in 15VDC even though it is capable of handling 7 -30 V. Why is it getting so hot to the point where I burn my self and the thermal protection turns on? I hope this makes any sense. If you know what I am trying to say, is this a good or efficient way to variable control the fan? Any advice and help would be highly appreciated.
#2
Can you post a schematic of how you have things wired up?
What is the part number of the MOSFET? Include that on your schematic.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
#3
We need to know more about the circuit. How much power does the fan draw, and how are you using the pot to control it? A schematic would help.
Part of the regulator's problem is that it has so much voltage presented to it. 10 of those 15 volts is lost as heat according to the power formula P = I*E. If your fan needs 500 ma current, for instance, the power dissipated by the 7805 is .5 * 10, or 5 watts. You would have to add a heat sink to properly cool the regulator.
__________________
First comes the hardware, then the software. |
#4
What is the pot value 10Ω? disconnect all of it except the pot and see if your heating problem disapear.
#5
Quote:
Another question, is this a logical way to reduce the input voltage by using a mosfet? or is there a much better, more efficient way to do this? |
#6
7805 is the the type number of a three terminal voltage regulator. See my above as to why it's getting hot.
The fan's 180 millivolts should not be too much of a load. But unless you're FET is logic level, the voltage out of the pot won't put it into full conduction. Most FET's need 10 volts on the gate relative to the source to full turn on.
__________________
#7
Quote:
| Bookmarks |
| Tags |
| 78xx, fet, mos, mosfet, pot, power, regulator |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| High Voltage MOSFET Drivers | ams0178 | The Projects Forum | 14 | 08-16-2008 04:25 AM |
| 555CN timer - relay or FET on output? | mezlo | The Projects Forum | 17 | 07-18-2008 06:26 PM |
| Boost energy & power flow (i/p to o/p) | reggiereggie | General Electronics Chat | 0 | 06-02-2008 01:42 PM |
| Drive an fet with a 555 and a different power source/not the same one that powers fet | arthur92710 | General Electronics Chat | 108 | 11-08-2007 07:51 PM |
| Digital MOSFET for power switcing form PIC | G0JLB | The Projects Forum | 4 | 10-03-2007 06:15 AM |
