All About Circuits - Newsgroup Archive Forum Index All About Circuits - Newsgroup Archive
These forums contain an archive of usenet posts relating to electronics. These usenet posts are a great resource. Click the 'search' link to search for a topic, or browse through the posts.
Back To: please note - you cannot post on these forums. this is a usenet archive, new posts are not permitted. please visit our forums to create a new post
   SearchSearch
PC KEYBOARD WIRING SCHEMATIC
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.basics
Author Message
Guest
PostPosted: Wed Dec 17, 2003 11:01 am    Post subject: PC KEYBOARD WIRING SCHEMATIC
I am trying to wire and old 1920's typewriter to a modern PS/2
connection, AT computer keyboard. I plan to basically remove the
control IC from an old keyboard, and wire each keyswitch connection to
a momentary button, which is hooked to mechanical levers in the
typewriter. Does anyone have a wiring diagram of the internal
keyswitches in a standard PC keyboard. I havent been able to fiond one
online, all i keep getting is PS/2 pinouts, or the pinouts for the IC.
thanks in advance,
-Rich
Back to top
CFoley1064
Guest
PostPosted: Wed Dec 17, 2003 5:55 pm    Post subject: Re: PC KEYBOARD WIRING SCHEMATIC
thanks in advance,
-Rich
Good morning, Rich. That's a cool idea, which should be quite a bit of work.
$2.50 will get you free advice and a cup of coffee at Starbucks, so for what
it's worth, a few observations....
The one time I wanted a keyboard schematic (arc-percussive welder/high noise
environment, wanted to do additional filtering of signals without
optocoupling), I had to call the keyboard manufacturer's US office and ask.
They sent one over with no problem. You might have to use the usual subterfuge
to get them to cooperate.
Communication between the PC and the keyboard is accomplished through a
proprietary serial communication protocol. The original IBM PC had a dedicated
Intel peripheral chip to accomplish this, and the AT and later keyboards use a
dedicated microcontroller IC in the keyboard which reads the key matrix and
then communicates the results to the PC. Since there aren't individual outputs
for each of the keys, you can't get there directly from the keyboard. Even if
you were to disable/remove the microcontroller and just run directly off the
individual keyswitches, the 102 keys are read by the microcontroller in a
matrix, so you will need to manufacture a scanner circuit to read the keyboard
matrix and translate the signals to individual outputs. For a hobbyist
project, this doesn't look too hopeful.
But, there are ways to get the cool effect you're looking for. First, I would
look at the IBM Selectrics (II and newer). They have a data port in the back,
where you can control the typewriter with outside logic level signals. A
friend did a PC/Selectric typewriter interface about 20 years ago, and was
happy with the results. A standard digital I/O board such as the Measurement
Computing CIO-DIO-48 ($119.99 USD) would be just about all you'd have to buy.
You could put that card in an old PC, sweat out the comm I/O and timing issues
in the programming flavor of choice, and you're good to go.
If you _really_ want to use individual solenoids to flip the levers, you might
want to try getting a couple of CIO-DO48-DD boards from Measurement Computing
($199.00 USD ea.). Each output can drive up to 500mA at 50VDC, which should be
enough for small solenoids (you're going to need a lot of those, too, but
that's another story). Slap those in an old PC, wire 'em up, program, and
you're done.
There are a lot of very difficult mechanical issues involved in getting enough
electrical solenoids into such a small space as the underside of an old
Underwood. The earliest electric typewriters were bulky, balky, and quickly
junked as better ones became available. Pretty steep learning curve there.
Summary:
1) Very difficult to do this without some kind of computer between the keyboard
and the typewriter.
2) Cool effect possible with IBM Selectric II or III.
Good luck.
Chris
Back to top
JW
Guest
PostPosted: Wed Dec 17, 2003 7:47 pm    Post subject: Re: PC KEYBOARD WIRING SCHEMATIC
On Wed, 17 Dec 2003 06:01:49 GMT datamancer0@hotmail.com wrote in Message
thanks in advance,
Unfortunately, what you ask for is near impossible. The keyboard x-y matrix
will vary from one manufacturer to the next. You'll have to pick your
keyboard, open it up and remove the PCB/controller, then ohm out your
specific matrix.
Back to top
Eric R Snow
Guest
PostPosted: Thu Dec 18, 2003 12:41 am    Post subject: Re: PC KEYBOARD WIRING SCHEMATIC
thanks in advance,
-Rich
Greetings Rich,
I had a similar question and the answer was a device called the IPAC.
This device is a keyboard emulator. What you do is wire switches to
the device and then program each switch. This is done by plugging the
IPAC into your computer and the keyboard into the IPAC. Then, press
the switch you want to program and the IPAC will tell you to press
the key you want to emulate. So it only requires you to press the key
on the old typewriter and then press the corresponding key on your
computer keyboard. After the IPAC is programmed the computer keyboard
can be removed. This is the simplest solution and it is working well
for me. I have no connection to the IPAC other than being happy with
the device and customer service. The IPAC 4 has 56 inputs and if you
need more they can be daisy-chained.The web address is:
www.ultimarc.com
I hope this helps.
Cheers,
Eric R Snow
Back to top
petrus bitbyter
Guest
PostPosted: Thu Dec 18, 2003 2:05 am    Post subject: Re: PC KEYBOARD WIRING SCHEMATIC
<datamancer0@hotmail.com> schreef in bericht
news:l5rvtv0fkin016bc4asp815abf2gen0cq1@4ax.com...
thanks in advance,
-Rich
Rich,
The keyboard interface to the PC has been defined. The inner workings of the
keyboard is up to the manufacturer. Most of the old keyboards I opened
contained an Intel 8048 micro with a 6MHz Xtal and some small amount of
other electronics. Keyswitches are usually placed in some matrix. Best thing
you can do is find an old AT-keyboard and wire the switches on your
typewriter according to the matrix. Then take over the keyboard electronics
as a whole.
petrus
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.547 / Virus Database: 340 - Release Date: 2-12-2003
Back to top
Tom Del Rosso
Guest
PostPosted: Sat Dec 20, 2003 10:17 am    Post subject: Re: PC KEYBOARD WIRING SCHEMATIC
In news:l5rvtv0fkin016bc4asp815abf2gen0cq1@4ax.com,
datamancer0@hotmail.com typed:
thanks in advance,
-Rich
In addition to the other caveats, the keys in some keyboards are
capacitive, which means they are not really switches at all. They would
be pieces of foil that just press down on top of PCB pads, but with an
insulator in between.
-Reply in group, but if emailing add 2 more zeros-
-and remove the obvious-
Back to top
Display posts from previous:
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.basics All times are GMT
Page 1 of 1
Jump to:
You can post new topics in this forum
You can reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
sitemap
