All About Circuits - Newsgroup Archive Forum Index All About Circuits - Newsgroup Archive
These forums contain an archive of usenet posts relating to electronics. These usenet posts are a great resource. Click the 'search' link to search for a topic, or browse through the posts.
Back To: please note - you cannot post on these forums. this is a usenet archive, new posts are not permitted. please visit our forums to create a new post
   SearchSearch
FET comparison chart
   All About Circuits - Newsgroup Archive Forum Index -> alt.engineering.electrical
Author Message
Peter
Guest
PostPosted: Fri Jun 08, 2007 7:47 am    Post subject: FET comparison chart
I've always been confused between JFETS, MOSFETS, Enhancement mode, etc...
Recently I did some reading and have a better understanding at the
differences. It appears JFETS are similar to BJTs, however, they have
higher input impedance and require negative voltage to turn off. MOSFETS
require 0 volts to turn off, and have high impedance.
All I'm pointing out is that I've done some research before I ask my
question.
Is there a comparison chart that shows all the variations between the
models? It seems MOSFETS require much less gate current than JFETS, but
each one has good and bad points.
It would be nice to see a chart laid out.
Thanks in advance.
Back to top
Salmon Egg
Guest
PostPosted: Sat Jun 09, 2007 8:20 am    Post subject: Re: FET comparison chart
On 6/7/07 8:47 PM, in article 7MGdnau6vOv6TPXbnZ2dnUVZ_vbinZ2d@comcast.com,
question.
In all FETS, the input signal controls the cross section or conductivity of
the conducting channel. It how that is done that leads to all the FET
variations.
A JFET and BJT are completely different except for the material (usually
silicon) used to make them. The conductive channel width of the JFET is
controlled by reverse drive on the junction. In structure, it is somewhat
similar to a unijunction transistor.
Bill
-- Support the troops. Impeach Bush. Oh, I forgot about Cheney.
Back to top
1fine@itude
Guest
PostPosted: Sun Jun 10, 2007 8:00 am    Post subject: Re: FET comparison chart
Peter wrote on 07-06-07 20:47 :
MosFETs don't require Gate current, unless you consider very high
frequency (Gate capacitance), hence the "Metal-Oxide-Semiconductor"
portion of the acronym. Junction FETs do require finite gate current.
Before you go further, decide what you mean by "good and bad".
Try undergraduate EE courses and class material, unless, of course,
Google is still down.
Back to top
Display posts from previous:
   All About Circuits - Newsgroup Archive Forum Index -> alt.engineering.electrical All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
sitemap
