All About Circuits - Newsgroup Archive Forum Index All About Circuits - Newsgroup Archive
These forums contain an archive of usenet posts relating to electronics. These usenet posts are a great resource. Click the 'search' link to search for a topic, or browse through the posts.
Back To: please note - you cannot post on these forums. this is a usenet archive, new posts are not permitted. please visit our forums to create a new post
   SearchSearch
Datasheet for TC40107B
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.repair
Author Message
Sam Goldwasser
Guest
PostPosted: Wed Feb 15, 2006 12:51 am    Post subject: Datasheet for TC40107B
Any takers? It's an 8 pin DIP found on a barcode scanner laser
diode driver PCB.
Google appeared to be hopelessly useless.
There's also an 8 pin SMT part labeled:
5223
172
Thanks.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Back to top
kip
Guest
PostPosted: Wed Feb 15, 2006 1:21 am    Post subject: Re: Datasheet for TC40107B
I have it Sam .
K i p at our . c a
email me.
"Sam Goldwasser" <sam@saul.cis.upenn.edu> wrote in message
news:6wd5hpn2hn.fsf@saul.cis.upenn.edu...
diode driver PCB.
5223
172
Thanks.
is
in the
Back to top
JFETR
Guest
PostPosted: Wed Feb 15, 2006 1:33 pm    Post subject: Re: Datasheet for TC40107B
try a search for
40107b without the "TC"
On 14 Feb 2006 14:51:00 -0500, Sam Goldwasser <sam@saul.cis.upenn.edu>
wrote:
diode driver PCB.
5223
172
Thanks.
Back to top
n cook
Guest
PostPosted: Wed Feb 15, 2006 2:05 pm    Post subject: Re: Datasheet for TC40107B
Sam Goldwasser <sam@saul.cis.upenn.edu> wrote in message
diode driver PCB.
5223
172
Thanks.
is
in the
Toshiba CMOS NAND ?
1 in A
2 in B
3 NOT (A AND B )
4 Vss
5 NOT (D AND E)
6 in E
7 in D
8 Vdd
open collectors it says in D.A.T.A, V max 15V
Diverse Devices, Southampton, England
electronic hints and repair briefs , schematics/manuals list on
http://home.graffiti.net/diverse:graffiti.net/
Back to top
Sam Goldwasser
Guest
PostPosted: Wed Feb 15, 2006 7:20 pm    Post subject: Re: Datasheet for TC40107B
"n cook" <diverse8@gazeta.pl> writes:
diode driver PCB.
5223
172
Thanks.
Toshiba CMOS NAND ?
1 in A
2 in B
3 NOT (A AND B )
4 Vss
5 NOT (D AND E)
6 in E
7 in D
8 Vdd
Probably, thanks. Too bad it's such a boring chip. :)
Back to top
Guest
PostPosted: Wed Feb 15, 2006 9:47 pm    Post subject: Re: Datasheet for TC40107B
I haven't downloaded to check but this may help
http://www.datasheets.org.uk/search.php?q=TC40107B&sType=part&ExactDS=Starts
Back to top
Sam Goldwasser
Guest
PostPosted: Wed Feb 15, 2006 11:08 pm    Post subject: Re: Datasheet for TC40107B
datasheets@dialelec.com writes:
Yes, thanks, that is the correct one.
Back to top
Franc Zabkar
Guest
PostPosted: Thu Feb 16, 2006 7:58 am    Post subject: Re: Datasheet for TC40107B
put finger to keyboard and composed:
diode driver PCB.
5223
172
How about a dual single supply op-amp:
M5223FP.pdf (flat DIP)
Datasheet available from http://www.alldatasheet.com/.
Also try http://www.cpcares.com/pdf/M5223P.PDF (SIP & DIP versions)
- Franc Zabkar
Please remove one 'i' from my address when replying by email.
Back to top
Sam Goldwasser
Guest
PostPosted: Thu Feb 16, 2006 6:06 pm    Post subject: Re: Datasheet for TC40107B
Franc Zabkar <fzabkar@iinternode.on.net> writes:
5223
172
Thanks. That is what I expected. These circuits almost always have
a garbage dual op-amp.
Back to top
Display posts from previous:
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.repair All times are GMT
Page 1 of 1
Jump to:
You can post new topics in this forum
You can reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
sitemap
