All About Circuits - Newsgroup Archive These forums contain an archive of usenet posts relating to electronics. These usenet posts are a great resource. Click the 'search' link to search for a topic, or browse through the posts.
Search
Back To:
please note - you cannot post on these forums. this is a usenet archive, new posts are not permitted. please visit our forums to create a new post
| Author |
Message |
clicliclic Guest
Posted: Sat Jan 08, 2005 11:54 am Post subject: RRe: transistor equivalent |
"R.Lewis" wrote:
| Quote: |
Does anyone know a near equivalent to a BUK555 100A.
I have been searching for yonks now - still 157gigahits to inspect - but
haven't got very close yet.
Thanks in anticipation
BUK555-100A MOS-N-FET 100V, 25A, 125W, 0.08Ohm
Hope this helps,
Martin. |
| Back to top |
R.Lewis Guest
Posted: Sat Jan 08, 2005 5:41 pm Post subject: Re: transistor equivalent |
"clicliclic" <clicliclic@freenet.de> wrote in message
news:8b226cfb.0501072254.4bac69ab@posting.google.com...
| Quote: | Hi,
Hope this helps,
Martin.
Thanks for that but I know what it is - I just need a replacement as it is
obsolete.
(There are quite a number still in circulation with the obsolete stockists
but buying them will only delay the inevitable as this device is used in a
current product not down for design review for 18 months.)
regards |
| Back to top |
Winfield Hill Guest
Posted: Sat Jan 08, 2005 8:09 pm Post subject: Re: transistor equivalent |
R.Lewis wrote...
| Quote: |
clicliclic wrote ...
to inspect - but haven't got very close yet.
replacement as it is obsolete.
One thing about the BUK555 is that it's a "logic-level"
FET. These have their Rds and Id-max specs made with
Vgs = 5V (compared to most FETs at Vgs = 10V). Here are
replacement candidates, plus your FET for comparison.
part number Vdss Idmax Pd Rds(on) Ciss
BUK9575-100A 100V 23A 98W 0.075 ohm 1704pF
BUK555-100A 100V 25A 125W 0.085 ohm 1750pF
IRL540A 100V 28A 121W 0.058 ohm 1580pF
FQP33N10L 100V 33A 127W 0.055 ohm 1630pF
BUK9540-100A 100V 39A 158W 0.040 ohm 3072pF
STP40NF10L 100V 40A 150W 0.036 ohm 2300pF
The Idmax and Pd specs are for a 25C case temp, and Rds(on)
is max, with Vgs = 5V. Ciss is measured at Vds = 25V.
These FETs are in the sweet spot for the new 42V automotive
electronics requirements, so they should be inexpensive.
The Fairchild FQP33N10L is one of my stocked parts, they
cost me 81 cents each at Newark.
There are plenty of parts with larger dies, lower Rds(on)
and rated at higher currents, but these have higher Ciss
and are probably more expensive.
Thanks,
- Win |
| Back to top |
R.Lewis Guest
Posted: Sun Jan 09, 2005 1:08 am Post subject: Re: transistor equivalent |
"Winfield Hill" <hill_a@t_rowland-dotties-harvard-dot.s-edu> wrote in
message news:crot3s02048@drn.newsguy.com...
| Quote: | R.Lewis wrote...
Thanks,
- Win
Thanks very much for that.
As you state these are 'logic level' devices with specification at a low
Vgs - a very important attribute in the design |
| Back to top |
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
