All About Circuits - Newsgroup Archive Forum Index All About Circuits - Newsgroup Archive
These forums contain an archive of usenet posts relating to electronics. These usenet posts are a great resource. Click the 'search' link to search for a topic, or browse through the posts.
Back To: please note - you cannot post on these forums. this is a usenet archive, new posts are not permitted. please visit our forums to create a new post
   SearchSearch
Measuring S - Parameters in Spice
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.cad
Author Message
Paul Burridge
Guest
PostPosted: Fri Aug 06, 2004 3:51 pm    Post subject: Measuring S - Parameters in Spice
Hi all,
I flicked through Google last night and saw some quite simple set-up
whereby, given an accurate enough transistor model, one might measure
S - parmaters for any device under consideration purely via
simulation. Is this feasible? Or is it really only possible to
reliably do this empirically with real components?
Thanks,
p.
"What is now proved was once only imagin'd." - William Blake, 1793.
Back to top
Kevin Aylward
Guest
PostPosted: Fri Aug 06, 2004 3:51 pm    Post subject: Re: Measuring S - Parameters in Spice
Paul Burridge wrote:
Quote:
Hi all,
I dont follow what you are asking for. A bit of confusion between
"measurement" and "simulation" here.
*All* the parameter sets (h, s, abcd etc) are mathematicly *identically*
equivalent. A far as simulation goes, it don't care a toss what set you
use.
S - parameters came into use for R.F, because it is easier to *measure*
S parameters in the real world at high frequencies. By and large, S
parameters themselves, in my opinion, are a pain in the arse. If you can
get a good spice model at h.f, you are better using it, especially,
because this will allow one to do transient simulation as well.
Kevin Aylward
salesEXTRACT@anasoft.co.uk
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
Back to top
Paul Burridge
Guest
PostPosted: Sat Aug 07, 2004 10:18 pm    Post subject: Re: Measuring S - Parameters in Spice
On Fri, 06 Aug 2004 14:38:22 GMT, "Kevin Aylward"
I think you know. I've since Googled a bit more and found that
"gwhite" (can't recall his first name off hand, but he's the author of
the VHF/UHF DX Handbook) posted to one of the radio amateur groups
that he'd had more accurate results 'measuring' S-parameters from
Spice simulations than the manufacturers provided in their datasheets.
He was able to 'adjudicate' between the sheets and Spice by virtue of
having access to a decent VNA.
use.
True enough.
Indeed? I'm surprised. Measuring them might be a pain in the arse, but
once you have them, they do make it much easier to visualise any
mis-match when subsequently plotted on Mr. Smith's chart.
Quote:
If you can
Whatever, but what I'm trying to arrive at is a circuit simulation
which will enable the modulus and phase-angle components of reflected
waves to be displayed via Spice. If you or anyone else can come up
with an accurate way of doing so, then I'd be interested to hear about
it.
p.
Back to top
Robert
Guest
PostPosted: Sun Aug 08, 2004 2:39 am    Post subject: Re: Measuring S - Parameters in Spice
it.
Easily done.
The biggest problem is the S Parameters vary with bias on the Transistor.
But you should get reasonable results at different bias points off a good
Spice Model.
I have an old 2 page App Note from Wes Hayard (W7ZOI) in DOC format that
describes a setup that will work in all the various Spices. If you provide
an address (suitably camouflaged) I'll send it.
But essentially you drive the device you want to measure the S Parameters
with a 2 volt AC source through a 50 ohm series resistor. The other end of
the source is tied to ground. That is, if the impedance of your system is 50
ohms.
In shunt with this connection to the device is one side of another 1V AC
source, set so it subtracts 1V of the applied 2V signal on the side not
connected to the device input.
That side of the 1V AC source is tied to ground through a high value (1Meg)
resistor.
Then the voltage at the top of that high value resistor will be S11.
If you tie the output connection of the device you're trying to measure the
S Parameters to 50 ohms to ground (use a coupling cap if necessary) then the
voltage at the top of that 50 ohm load to ground will be S21.
Turn this around to measure S22 and S12.
Robert
Back to top
Chaos Master
Guest
PostPosted: Sun Aug 08, 2004 3:43 am    Post subject: Re: Measuring S - Parameters in Spice
Robert, Robert, Robert.... did you really write this article
(<aScRc.12272$9Y6.10039@newsread1.news.pas.earthlink.net>) in newsgroup
(sci.electronics.cad) at the date of (Sat, 07 Aug 2004 22:39:02 GMT)?
[S Parameters in SPICE]
I am interested in this app note, can you send it to me?
renan_tdb AT yahoo DOT com DOT br
[]s
Chaos Master®, posting from Brazil. REPLY TO GROUP!
MSN: wizard_of_yendor[@]hotmail[.]com http://marreka.no-ip.com
"You're guilty; the punishment is death for all who live."
-- Iron Maiden, "Out Of The Silent Planet"
Back to top
Paul Burridge
Guest
PostPosted: Sun Aug 08, 2004 3:58 am    Post subject: Re: Measuring S - Parameters in Spice
Sounds just what I'm looking for. Thanks, Robert. Address is
pb@osiris1.co.uk with no mods needed to reach me. I just don't care!
Best regards,
paul
Back to top
Kevin Aylward
Guest
PostPosted: Sun Aug 08, 2004 10:28 am    Post subject: Re: Measuring S - Parameters in Spice
measure S - parmaters for any device under consideration purely via
*identically* equivalent. A far as simulation goes, it don't care a
toss what set you use.
True enough.
*measure* S parameters in the real world at high frequencies. By and
large, S parameters themselves, in my opinion, are a pain in the
arse.
I don't use Mr. Smith, that's an even bigger pain in the arse.
Quote:
If you can
Why? These "waves" do not "exist", i.e they are imaginary, in a lumped
component model such as a spice one.
Kevin Aylward
Back to top
Paul Burridge
Guest
PostPosted: Sun Aug 08, 2004 3:03 pm    Post subject: Re: Measuring S - Parameters in Spice
On Sun, 08 Aug 2004 06:28:15 GMT, "Kevin Aylward"
I know what you mean, Kev, but this is the very reason I'm posting the
question. It *is* possible to contrive a simulation to establish a
device's S -parameters in Spice, notwithstanding real-world
distributed reactances. I simply would like to know *how* it's done!
Back to top
Jim Thompson
Guest
PostPosted: Thu Aug 12, 2004 4:38 am    Post subject: Re: Measuring S - Parameters in Spice
On Fri, 06 Aug 2004 14:06:52 +0100, Paul Burridge
<pb@notthisbit.osiris1.co.uk> wrote:
Quote:
Hi all,
Thanks,
p.
It's in this list of app notes:
http://www.orcadpcb.com/pspice/applicationnotes.asp?bc=F
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice:(480)460-2350 | |
| E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
| http://www.analog-innovations.com | 1962 |
I love to cook with wine. Sometimes I even put it in the food.
Back to top
mehran gupta
Guest
PostPosted: Thu Aug 12, 2004 7:39 pm    Post subject: Re: Measuring S - Parameters in Spice
The article below shows a good method to measure the S-parameters
using Micro-Cap. It should work with any simulation programme.
http://www.spectrum-soft.com/news/winter2001/sparameters.shtm
mehran
Paul Burridge <pb@notthisbit.osiris1.co.uk> wrote in message news:<es1ch0d2ma03ihnaecee2jckm1o6m384d0@4ax.com>...
Back to top
Paul Burridge
Guest
PostPosted: Thu Aug 12, 2004 8:23 pm    Post subject: Re: Measuring S - Parameters in Spice
On 12 Aug 2004 08:39:20 -0700, mehran_gupta@yahoo.com (mehran gupta)
mehran
Many thanks, Mehran. That's just the kind of info I'd be trawling the
'net for and been unable to find.
Regards, Paul
Back to top
Display posts from previous:
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.cad All times are GMT
Page 1 of 1
Jump to:
You can post new topics in this forum
You can reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
sitemap
