All About Circuits - Newsgroup Archive Forum Index All About Circuits - Newsgroup Archive
These forums contain an archive of usenet posts relating to electronics. These usenet posts are a great resource. Click the 'search' link to search for a topic, or browse through the posts.
Back To: please note - you cannot post on these forums. this is a usenet archive, new posts are not permitted. please visit our forums to create a new post
   SearchSearch
clock chip with multiplexed BCD output ?
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.components
Author Message
Gerry Jacobs
Guest
PostPosted: Wed Dec 10, 2003 3:51 pm    Post subject: clock chip with multiplexed BCD output ?
I am intending to build a Nixie clock with the SN74141 as driver for the
nixies. The 74141 takes BCD as input.
Is there any clock chip out there which provides BCD output and seperate
signal pins for each digit to multiplex the BCD output across the four
digits ?
All I could find are chips which drive LCDs directly. However output to
control the LCD/LED segments is not particulary useful since I need BCD
input.
I really would like to save the expense to use a microcontroller to do the
job.
TIA
Gerry
Back to top
Sal Brisindi
Guest
PostPosted: Thu Dec 11, 2003 7:08 am    Post subject: Re: clock chip with multiplexed BCD output ?
Gerry,
There were many clock ic's manufactured with BCD outputs but good luck trying
to find them. The numbers are MM5311, MM5312, MM5313 and I think MM5315. The
other one is FCM7002 (CT7002) with alarm and calander. There is a decoder chip
you can use that decodes 7 segment to BCD, that chip is the rare 74C915. but
you can find it for about $7.00 and use the MM5314 clock ic which is still
available. Hope this information helps.
Sal
www.tuberadios.com/nixie
digits ?
input.
job.
TIA
Gerry
Back to top
Michael
Guest
PostPosted: Thu Dec 11, 2003 10:56 am    Post subject: Re: clock chip with multiplexed BCD output ?
digits ?
input.
job.
TIA
Gerry
Expense? Implement both the clock and the BCD generator with just a
micro. Since I happen to be a PIC bigot I would use a $2.60 PIC16F628,
but an Atmel or Motorola or whatever would do just as well.
Back to top
Sal Brisindi
Guest
PostPosted: Fri Dec 12, 2003 5:49 pm    Post subject: Re: clock chip with multiplexed BCD output ?
Michael,
I would love to learn how to program am Pic or AVR so I can create my own clock
ic's. I have a bunch of the Atmel 2313'2 and a developement board, one day I
have to sit down, read a book and give it a shot.
Regards,
Sal
digits ?
input.
job.
TIA
Gerry
Back to top
Michael
Guest
PostPosted: Sun Dec 14, 2003 10:05 pm    Post subject: Re: clock chip with multiplexed BCD output ?
Sal Brisindi wrote:
Quote:
Michael,
Regards,
Sal
Sounds like you have what you need to get started. Go for it. I think
you won't regret it. uC's are great little tools; cheap, very capable,
very flexible. Though the learning curve might be steep - depends on
the learner's aptitude and capabilities - like anything else worth doing
it's worth the effort.
I'm an old guy (50+) who started out with tubes in the early 1960's,
moved to semiconductors in the late 60's, and to IC's (TTL) in 1969.
Six years later I started and then finished an EE degree, went to work
for a major large computer company for 15 years, and only after all of
that water was under the bridge did I get my feet wet in micros.
Started with the Z80 in 1994 when the Z80 was all but dead. Quickly
moved to PICs, the 16F84, then 16F84A, and finally the 16F628. I prefer
100% assembly language, never use a compiler or interpreter. Assembler
keeps the mind sharp, in my opinion. Wink
Back to top
Display posts from previous:
   All About Circuits - Newsgroup Archive Forum Index -> sci.electronics.components All times are GMT
Page 1 of 1
Jump to:
You can post new topics in this forum
You can reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
sitemap
